Martin Wizard Rush
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Martin Wizard Rush
Post by perrip »
Hello, I have been trying to make a fixture for the Martin Wizard Rush. It is a complicated fixture, at this point I really just need the basics. If I use a generic 10 channel fixture file, I can control it just fine. If I load mine it is unusable. I am wondering if someone could take a look and tell me what I am doing wrong. Any help would be great. Thanks so much
Paul
UM_RUSHWizard_EN_E.pdf
(1.1 MiB) Downloaded 22 times
Wizard Rush.pff
(127.27 KiB) Downloaded 20 times
Re: Martin Wizard Rush
Post by Jan_K »
Hej Perrip
You don't write what is not working so this is just some small comments.
I can see that you have channel 6 on pan and 7 on tilt.
Think that I would place channel 5 on tilt and 6 on pan as the manual suggest and the channel 7 on custom sliders and evt. add some macros.
Also I can not see that you use channel 8 anywhere. Don't you need "Power lamp on" and "Power lamp off"
And I think you need to update the "Channel description"
perrip
Post by perrip »
Hey Thanks so much, yes you are right, I could not even turn it on. I will make those corrections. Really appreciate you looking at it for me!!
