hardware
sebastiano78
I Use FreeStyler for: Theater
hardware
Post by sebastiano78 »
hello I already have a hardware system but the proprietary software is not the best you can use freestyle with the QUICK DMX D1024 interface
https://www.highlite.com/en/50056-quick-dmx-d1024.html
FreeStyler Version: 4.01
Re: hardware
Post by Partyman »
English may not be your language but in order for us to help you need to use punctuation. I cannot tell if you are making a statement or asking a question.
SiGNe
FreeStyler Version: 4.14
Re: hardware
Post by SiGNe »
Partyman wrote: 11 Sep 2021, 03:14 English may not be your language but in order for us to help you need to use punctuation. I cannot tell if you are making a statement or asking a question.
I guess he want to know if the showtec Quick DMX 1024 is supported in Freestyler, it's not in the list of devices.
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Re: hardware
Post by perrip »
It says in the add for the Showtec Quick DMX 1024 that it can only be used with their software. It can't hurt to try though, Hook up a light to it and go through all the controller options and see if it works.
