Is there a way to export saved scenes to a stand alone device?
I'm thinking about this software, and these stand alone devices, like the "MyDMX RM".
stand alone device? Topic is solved
j_dunavin
xever
- Twitter: www.120db.uk
Re: stand alone device?
Thats more on the standalone device rather than freestyler.
Most standalone devices have a function to allow you to record into it, it's usually one scene at a time and step by step, with no special export feature required from Freestyler.
Short answer: Yes you can export into a standalone device.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
tho
How do you export with freestyler to a dmx stand alone player?
I Have the Enttec dmx usb pro mk2.
- FreeStyler Version: 4.01
You would hook up dmx to recorder an it will record what you are doing. there is no export for that
