I created a VR DanceHall with some DMX fixtures and I want to control it from the FreeStyler software. I can't figure out what output option is right for me. I tried the virtual output but this is a window only.
So I can catch LAN or serial output from my VR software but what can I do ?
Gabor
Output to VR Topic is solved
- FreeStyler Version: 4.1
- Twitter: www.120db.uk
Re: Output to VR
Artnet allows you to output DMX over a local network.
Setup your universe to use the "artnet device" as the output. You can either use broadcast or unicast.
Enter in the IPaddress of the machine hosting your VR software to enable unicast.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
