I am using FS2 V3.5.7 on a battered old laptop. I would like to run it on my touch screen laptop so downloaded V4.1.
Started setting up, plugged Entec Pro Mk11 into USB and selected it in dropdown list. In the FTDI device box it states NO USB DEVICE FOUND... i Rebooted and still same message.
Help please... many thanks...
USB interface issue, Topic is solved
- FreeStyler Version: 3.5.7
- FreeStyler Version: 4.01
Re: USB interface issue,
sounds like you need to reload device drivers. Make sure in "device manager" the device is installed properly.
during load, a pop up wanted me to download additional drivers, my virus checker keep quarantining a file. will try and re download them,,,
