Hi. I can't find a difference in the CUE Buttons options
Disable all buttons X Disable all others buttons?
Thanks for the reply
4.1 difference Disable all buttons X Disable all others buttons Topic is solved
- colombo
- FreeStyler Version: 4.1.7
- FreeStyler Version: 4.01
Re: 4.1 difference Disable all buttons X Disable all others buttons
"Disable all buttons" when active it disables ALL buttons(it is just creating a disable all "button")
"Disable all other buttons" disables all buttons EXCEPT the one activated and runs whatever is loaded to that button
- colombo
Thanks for the reply.
