Programmer help!
FreeStyler Version: 4.01
Programmer help!
Post by Partyman »
Can any of you wizards write an app that will batch open all of our freestyler cues and save them to the new format? This would be a great help to the community and countless hours. Old files are .chb and new files are .chs (no idea if you can just change the extention)
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Re: Programmer help!
Post by perrip »
I just tried a program called Bulk Extension Changer (link included) and it did work as far as changing file extensions from chb to chs, but I did not test if simply just changing the file extension will work.
https://sourceforge.net/projects/b-e-c/
