Audio bpm control
freeosca
Audio bpm control
Sorry for my bad english...
Just before use Freestyler, i would like to know if your soft can gettin input of my soundcard and control my scan ?
Because sometimes I'm looking for an automatic control with bpm... (randomize or not)
I hope you understand what i talk about ! lol
Best regards,
Oscar
Best regards,
Oscar
kikabyte
Re: Audio bpm control
BUT, there is about a second and a half delay when using Freestyler on Vista... Not very impressive for BIG shows, but ok if its just triggering a few scans...
Marc2405
- FreeStyler Version: 2.96j
Hi kikabyte and all the others, yes, there is a delay when using Freestyler with Vista. As I mentioned in one of my earlier posts, Vista seems to have some kind of complex driver architecture. I tried to update the audio driver for my soundcard, but it didn't change a thing. The device is called HD audio device and seems to be a generic driver issued by Realtek. However, it works fine under XP, but shows the delay you pointed out. Even external soundcards don't really make a difference. Apparently there is an external Soundblaster soundcard available, but I don't want to spend 100 bucks on it.
So let's hope that the next Freestyler version has the "Vista delay bug" fixed.
Practice and enjoy (yeah, I know that this is just quotation)!
Marc
BTW: Check out Brian's YouTube site, that guy is awesome!
http://www.youtube.com/user/briansredd
Marc
freeosca
Ok thanks a lot !
I bought the enttec pro and i'll test freeStyler in few days.
No problem for 'latency' (delays if you prefer lol), i'm using Xp and soundcard audigy2...
And i just control two Robe Djscan250xt, so i hope its easy for the hard and your soft...
I'll comeback for talk about my test !
freeosca
hi,
I tested with 2.96j, no latency, its ok for React to sound.
But, with, the '3', i can see the sound in Vumeter. But nothing move.
May be a bug or not.
I think i'll make a new post for this.
UTerror
freeosca wrote:But, with, the '3', i can see the sound in Vumeter. But nothing move.
Same here. Tested 3.0 on 2 pc's (vista and xp) and react to sound doesn't work @ all.
Kai-Uwe
Ups! I just see this: I have createt a new Post for it sorry!
Same Prob. is mine!
Help!
Greetings Kai-Uwe
Same Prob. is mine!
Help!
Greetings Kai-Uwe
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Hi Guys
Can everyone check their freestyler.ini file and look for all the "sendmessage=0" entries and change it to "sendmessage=1".
Also if you find double entries in the freestyler.ini file you should remove them.
Keep me informed about this issue so I can find a solution asap.
Best regards
Raph
Best regards
Raph
Raphaël
UTerror
checked freestyler.ini and found only 1 sendmessage.
It's part of [External control] and it is already =1.
