Reve-production is supported by freestyler but it doesn't seem to exist anymore... Where can I find the driver for my windows 10 computer?
How can I see the 3D of the light, I do not find it on the website...
Is there a function to program my light to go only 180 degree instead of 360 and light up a wall in the back
Is the Kinta from Chauvet exist already in the fixture? I do not find it... I've only found my strobe and my 6 American DJ spot 250.
And finally, what should I buy to control my fixtures with Freestyler for Android and program my fixture with my android phone or tablet?
Thanks for your precious help
A desperate guy that wanna learn dmx stuff
Many question from a begginer in dmx
- Just started using FS
- FreeStyler Version: 3
- Instagram: villeric
- Twitter: www.120db.uk
Re: Many question from a begginer in dmx
#The 3D visualiser can be installed during the Freestyler installation, reinstall freestyler and select that easyview 3d is also installed, The Wiki has a good tutorial on how it can be used.
#Go to Freetyler Setup -> Prefences, Pan/Tilt resize.
Yoy can then set a global limit on pan tilt, this may be what you are needing, else you may want to make a version of your sequences that are front facing only.
#You may need to create your own fixture, the wiki has a tutorial on fixture creation.
#For Android you will need a wireless router that is connected to both your laptop/pc and your Android device.
Ensure your windows firewall allows Freestyler access.
The android app will automaticallt find and configure itself.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
