Strobe effect without strobe-channel
Taske
Post by Taske »
Hello everbody,
I hope everybody is safe & well.
I am pretty sure someone asked the same question before, but I got no luck finding a thread for it.
'have normal 4 channel LED Decoder for LED-stripes
Sadly i cannot make them 5-6-7 channel mode, so I just have normal 'dimmer' channels for R G B & W.
Is there a way how to make a chase/sequence using the dimmers only to get a strobe effect?
My problem using the Sequence creator is, that I cannot lower the fade-time more then 500.
So my strobe effect wont be like a real strobe. It still fades a little bit, regardless how high I put the speed.
Please don't beat me for that question ;D still trying to learn.
kind regards
Taske
