Need help Cue And Sequence
guan2015_2015
Just started using FS
FreeStyler Version: 3
Post by guan2015_2015 »
I See On The Freestyler have just 32 Sequence,,,
i need more sequence style 64 and 128,,,
this is possible and if yes,, how i can find this manipulation,,,, because i search more and more on the youtube, and i not have find it,,,,
Thanks All For Read,,,
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Re: Need help Cue And Sequence
Post by perrip »
Hello, I may not be understanding you, but if this helps, the standard cluelist usually holds 20 Sequences, but you can have multiple cluelists and put all your other sequences there.
