Hello there!
How can i do a time trigered scene?
For example i have a room with static lights that i wan't to change different values using the
SEQUENCE PLAYBACK but i want to triger them with my PC clock.
i want to triger one scene at 10:00 am another one at 12:00 pm and another one at 3:30 pm.
How can i do it?
[flash=]Help please....[/flash]
Time trigerd scenes & cues Topic is solved
- djSupport
Re: Time trigerd scenes & cues
erm in the cue list its called timecode or something or other
newton2013
On the CUE list, Top Left, Click Options > Enable Timecode> PC Timecode Realtime.
It should sync to your computers clock.
Scroll thru the cue list sideways to find the place to enter the times per cue.
Cheers.
Cheers.
