This Lite version of our Freestyler Remote extends Freestyler by giving you remote access to some of the common Freestyler actions, and once you have outgrown this; Get full control using Freestyler DMX :: Remote available from the app store.
Auto Connection No IP address required, Locates, and Connects to Freestyler Automatically. No External Server Needed.
FREE Features:
Sequence Playback: 10 Cue Toggle Buttons, and tap sync (long press to release).
10 overrides loaded from page one.
MasterFader / Locate / Fog Machine Control.
Auto-connect on both WIFI and Hotspot.
Fetch Fixture Patch List.
Supports dual ports for connection with VirtualDJ.
NO ADS, NO TIME LIMITS, If you do use this app commercially please consider purchasing the full version.
https://play.google.com/store/apps/deta ... rts.fsFree
Freestyler Play (FREE)
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
SiGNe
- FreeStyler Version: 4.14
Re: Freestyler Play (FREE)
Great app, i really use it daily.
Mostly only the fade in/out button (it's for home use) but it works great and fast.
SiGNe
The app doesn't work with the new beta version 4.1.2
i can connect but the master intensity doesn't work)
Normally is didn't use wifi to connect with Freestyler but lately (with Freestyler 4.1.1) it didn't want to connect.
So better support for usage without Wifi would be nice.
(I have 10Gb data on my phone so i don't need to use Wifi plus then you can turn on and off your lights when you're not at home/work)
xever
- Twitter: www.120db.uk
Freestyler doesn't operate over the internet and requires a local wifi connection. It has been this way since day one.
Whilst this could be done over the internet it would require both your PC and Android device to be connected to the internet.
Would also require additional layers of security to prevent others from controlling your lights
would require me to host a server that connects the correct android device to the correct Freestyler PC would add subscription costs
local wifi connection is generally the most universally accepted method because of how easy and cheap it is for the users to implement.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
- djSupport
If you can make a server we'll host it
SiGNe
Version 4.1.3beta fixed it for me, i can connect again over the internet.xever wrote: 28 Nov 2022, 15:22 Freestyler doesn't operate over the internet and requires a local wifi connection. It has been this way since day one.
I do also have a portforward on my router.
When i use the fade in button the light don't fade in, the fade time does change from 1000ms to 2000ms and keeps going up when i press the fade in button.
The slider does work as it should.
I allready have a server (IIS based with php8.1 and Mysql8.0) so if i can help, i would do so gladly.
I have a 100/100Mbit connection with a double 10Gbit fibre backbone to the Utrecht University.
Not superfast but it's very very stable.
MrSleeps
I do hope you have some firewall rules on that port that restricts access to only allow certain IPs?Version 4.1.3beta fixed it for me, i can connect again over the internet.
SiGNe
On that port, yes but i have more ports open because it runs on my mail/webeserver, not on my daily use PC.MrSleeps wrote: 16 Dec 2022, 00:37I do hope you have some firewall rules on that port that restricts access to only allow certain IPs?Version 4.1.3beta fixed it for me, i can connect again over the internet.
