Equinox SpectraPix Batten
nicknock
MusicZon
- FreeStyler Version: 3.6.4
- Twitter: www.twitter.com/@music_zon
Re: Equinox SpectraPix Batten
You might have already done this but we have 8 of these in a separate universe on the 50+ channel setting we use them for walkways and side effects. You are welcome to our fixture file if it will help. If you have already got everything in place then please share some of your chases. It would be great to see what you have done with these little lights.
fulkatomas
- FreeStyler Version: 4.11
Please add fixtured for Equinox SpectraPix. Thank you
MrSleeps
Don't have the light myself but the fixture file is simple, here's a version for the 5 channel version.
If you want the 3, 24, 48 or 53 channel versions you can use the manual I've also attached to edit/create the fixture file yourself. (Wiki entry on using the fixture creator is here: https://www.freestylersupport.com/wiki/fixture_creator)
Donzo_p
- FreeStyler Version: 3.6.51
Hi, could you please upload your 50 channel file for the Spectrapix Batten? Thank you.MusicZon wrote: 26 May 2021, 17:21 You might have already done this but we have 8 of these in a separate universe on the 50+ channel setting we use them for walkways and side effects. You are welcome to our fixture file if it will help. If you have already got everything in place then please share some of your chases. It would be great to see what you have done with these little lights.
