Compatibility with tablet
Rubenfilipe
Post by Rubenfilipe »
Hello :) the computer that I'm using to control freestyler dmx died.. I have a backup of everything, can you tell me if I buy a tablet with usb ( I'm watching the chuwi hi10 xr) , it works with the software? The tablet have windows 10 and usb ports.
FreeStyler Version: 4.01
Re: Compatibility with tablet
Post by Partyman »
yes it will work, freestyler is very light. i have 2 chuwi tablets and can confirm freestyler running on the windows 10 side
Rubenfilipe
Partyman wrote: 26 Feb 2021, 08:05 yes it will work, freestyler is very light. i have 2 chuwi tablets and can confirm freestyler running on the windows 10 side
Thanks for your answer, and it works like the computer?
Rubenfilipe
And you have the dmx interface works ok connected diret to the tablet?
Post by Partyman »
yes
GalebG4M
I Use FreeStyler for: Theater
Post by GalebG4M »
Thanks for the explanations! Does it work only on a Windows handheld OS, or on Android (and iOS, for iPad users), too?
Post by Partyman »
only windows
GalebG4M
Post by GalebG4M »
Okay, thanks for the answer! Is Android compatibility something that could exist in the future?
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
GalebG4M wrote: 31 Mar 2021, 16:45 Okay, thanks for the answer! Is Android compatibility something that could exist in the future?
Freestyler is windows only but there is also a freestyler remote control app on android.
So i have Freestyler running on windows and i control my lights with the app on my phone.
GalebG4M
Post by GalebG4M »
Thanks, I'll look for that app then!
