Hello, please does anyone have developed a DMX fixture for this 38-channel moving 8-point LED light? (8 x RGBW)
https://www.aliexpress.com/item/3299845 ... 4c4daDX1Ih
Chinese led bar beam 8x12w rgbw 4in1 moving head ligh
cumacek666
VladimirN
- FreeStyler Version: 4.1.6
Re: Chinese led bar beam 8x12w rgbw 4in1 moving head ligh
At first, I also searched and found this message in the search, as a result, I created a fixture for Shehds Bar Beam myself. Perhaps it will be useful to someone.
BarBEAM 8x12_38.zip- (630 Bytes) Downloaded 401 times
Roadster_1913
- FreeStyler Version: X2
I know this is an old thread, but...
I have the same light bar, I am using your Fixture file, but the Red does not work. When I slide the red bar, it is green, when I slide the strobe slider the red appears. What am I doing wrong.
I tried to build my own before I found your file, thank you btw!
Any ideas what I am doing wrong here? It all looks good in the edit fixture page.
Roadster_1913
So... I removed the strobe channel (6) and lowered the RED channel to 6, the green to 7, Blue 8, White 9. They work then, but that's got to throw things off. Strange...
- FreeStyler Version: 4.1.7
Please post either a PDF of the user manual or a link to the user manual.
