U'King ZQ-B243 70 Watt Moving Head White
Lichtengel
FreeStyler Version: 4.0.1
Post by Lichtengel »
I start to create a completly folder with pictures, manual and fixture. It's my first time.
But I think there is a Probleme. The Global ID for the collors are not enough. Because the moving head have half/half colors and not a 2nd colorwheel.
Maybe there are more errors(macros what ever?). My brain stoping now. If some one can check this, I'm pleased.
Cheers yours Lichtengel
File checkit by virustotal
https://www.virustotal.com/gui/file/0cc ... /detection
U'King ZQB243 70 Watt Moving Head White only FXT.zip
just only my last .fxt
(800 Bytes) Downloaded 146 times
U'King ZQ-B243 70 Watt Moving Head White.zip
(586.38 KiB) Downloaded 142 times
Re: U'King ZQ-B243 70 Watt Moving Head White
Post by Jan_K »
Hej Lichtengel.
Please use the "export" function instead of zipping the files.
This will give a pff file which contain everything for the fixture. Images, icons usw.
Lichtengel
Hi!
Okay here it is.
cheers Lichtengel
U'King ZQB243 70 Watt Moving Head White.pff
(61.8 KiB) Downloaded 145 times
Post by Jan_K »
Hej
It looks fine and I have some minor comments.
To me it looks like you have swapped channel 2 and 3.
Regarding Global color ID's
You are only to have the numbers once in your color table. If you you have the same number twice then Freestyler don't which one to use. (I can see that you have 1 twice)
Also don't use the id's on half colors.
I can see in the data sheet that there are a color shift channel 5, 140 to 255.
If you want to add this to you color table then it can be done by adding 3 rainbow icons with the values
fast = 140, med = 198, slow = 255.
On the Gobo I can see that you can add some shaking and shifting functionality.
I think if you look at the mac250 moving head then it may give you an idea of how to implement this.
On the reset channel, Channel 11 you are to enter the value 255
And on the macro tab you have channel 9 = 255 ? That is the speed channel, any special use ?
Lichtengel
thanks to Jan_K
I modificated the fixture and I hope it's now correct. Please check it.
I tested the fixture and it works for me. I also sorted the gobos in the correct order.
Only I don't now how can I use the half colors, because there is no ID to push the collorbutton later inside freestyler.
Cheers Lichtengel
(73.5 KiB) Downloaded 153 times
Post by Jan_K »
Have a look under "Setup" -> "Use global colors"
If this one is checked "on" then change it to unchecked.
If "on" only colors which are global defined are shown. This is useful if you use more fixtures of different types. If you select a red with more different fixtures selected then the color with ID = 10 will be selected on all of them and in this case 10 is red.
Stevie73
FreeStyler Version: 4.1.1
I Use FreeStyler for: Bedroom Lighting.
Post by Stevie73 »
hat der moving rotierende gobos oder nur eine rotierende goboscheibe?
welche funktion hat kanal8: MOTOR SPEED?
- motor speed für pan / tilt motoren?
- oder doch rotations speed für einzelne gobos?
- oder rotations speed goboscheibe?
wenn ich den wert des kanals ändere tut sich nix am moving. also hab noch keine funktion gefunden was der kanal machen soll.
im text der beschreibung steht: der moving hätte pattern rotation ! heißt für mich: einzelne goborotation
hat jemand info?
DANKE
Stevie73
Post by Stevie73 »
does the moving have rotating gobos or just a rotating gobo disc?
what is the function of kanal8: MOTOR SPEED?
- motor speed for pan / tilt motors?
- or rotation speed for individual gobos?
- or rotation speed gobo disc?
if I change the value of the channel, nothing happens on the moving. so I haven't found a function yet what the channel is supposed to do.
in the text of the description it says: the moving would have pattern rotation! means for me: single gobo rotation
does anyone have info?
THANKS
Stevie73 wrote: 18 Mar 2023, 17:07 does the moving have rotating gobos or just a rotating gobo disc?
THANKS
Something like that would normally be Pan/Tilt Speed if not it could to do with the speed of 'auto' or 'sound' programs
