Enttec pro mk2 Topic is solved
perrip
Commited FS Forum helper
FreeStyler Version: 4.6
Enttec pro mk2
Post by perrip »
Hello, I have not had any luck getting the second universe working for this, when using that controller what do you select for the first and second universe to make it work? thanks so much with any help with this!!
perrip
Re: Enttec pro mk2
Post by perrip »
I have been using just entec pro for the first universe, just not sure if I should add enttec pro mk2 for each universe. the controller is at a venue, and I have limited access just trying to find out what has worked for other people.
Thanks again
perrip
Re: Enttec pro mk2
Post by perrip »
Hey thanks, I got it to work, just add the Enttec pro mk2 on each universe, for some reason the version of freestyler that I was using had mk2 in the list, but when you selected it, it just came up with Entec Pro
Return to “DMX Interfaces”
