Hi all,
I'm currently running a QTX MHS-30 mini moving head (please find attached the manual). Its 8 channel and I've attempted to create my own fixture for it. All gone well except from when I Pan ( not happening when tilting ) and I'm on the Open gobo (Ch3 000-011) the gobos start changing on their own. It cycles through all the gobos and then returns to the spot. This does not happen for any other gobo just this one!
Please also find attached my fixture for this light and a video of my problem.
Any help would be greatly appreciated as it is really bugging me.
Many thanks
Mateusz
https://drive.google.com/file/d/1LI1be8 ... sp=sharing
Moving head Gobo/Pan Issue
Mateuszdybowski
- FreeStyler Version: 4.0
MHS30.pff- Fixture
- (92.23 KiB) Downloaded 20 times
mhs30.pdf- Manual
- (163.2 KiB) Downloaded 22 times
draceq
- Just started using FS
- FreeStyler Version: 4.1.0
Re: Moving head Gobo/Pan Issue
Do you have more of this fixtures?
If so, put them on the same address and make a test.
If only this one is doing that, check cables inside and position of gobo hall sensor. Sometimes bad position or short circuit of hall sensor is doing this.
If all of them are behaving the same, check the DMX output values in the "Show output" window.
