Help With Midi Topic is solved
ned911
Help With Midi
Post by ned911 »
My foot controller is completely programmable. I've got 3 sequences in the Cue manager and midi notes mapped to each one (one is a black out). I can activate each sequence via the foot controller via midi note on/off's. The problem is I can only activate each sequence once.
For example: If I run a sequence that makes all the lights green then activate the blackout then the red sequence I cannot activate blackout again. Step on the button and nothing happens.
Any ideas?
FS - 2.96J
Midi is a M-Audio Midi Sport 2x2 connected via USB
Re: Help With Midi
[bugreporting][/bugreporting]
