some questions from a newbie {BCF2000} Topic is solved
Post by LJ_krede.dk »
Hi All
I just got the BCF2000 and have played with it some time, but have some questions
  • 1. What is the BCF2000 configuration file doing on the bcf?
    2. Where do i find the java version J2SE-1_4_2_05,
    • I can only find 1_4_2_14, is that good enough?
    3. can you pragramme the bcf/freesyler so each fader is controlling an invidual fixtures intensity? If yes, how?
    • I tried to figure this out by myself whithout any luck
    4. can you pragramme the bcf/freesyler so each fader is controlling an invidual fader in DMX400? If yes, how?
    5.any advice to get started with BCF?
sorry if the questions is quite obvious, I am a real newbie!!!! :?
thank you very much in advance for assistance
Best regards
Krede
Re: some questions from a newbie {BCF2000}
I can imagine thats better than enouth as its newer!
actually, it is 1_4_2_18,, my bad :?
but thanks. I just wanted to be sure that it shouln't be exactly that version.
I can see that some of my questions is allready answered in some of the other topics. I'm sorry for that
/Krede
no problem, I'm one of those admin/mods that wont say to you 'search before asking' because i know my self searching usually doesn't help at all!
cantyco
Post by cantyco »
There was an issue with newer java versions not working correctly with the behringer software but this could have been fixed by now, but havent tryed it for so long i couldn't tell you.
Return to “BCF2000”
