NEED HELP Topic is solved
guan2015_2015
- Just started using FS
- FreeStyler Version: 3
NEED HELP
I have buy Freestyler 3
with driver,, all fonctionnal...
so the problem i can't find the library Fixture
for Moving Head LED 60 Watt With 3-Prism
https://www.aliexpress.com/item/3264791 ... 3e5fLPvLHO
1 Brand Name: MZMLing
2 Item Type: Stage Lighting Effect
3 Voltage: 90-240V
4 Occasion: Professional Stage & DJ
5 Style: DMX Stage Light
6 Model Number: NO.037
7 Power: 90W
8 Power Input: 90-240V,50/60Hz
9 Power consumption: 90W
10 LED Source: 60W White LED
11 DMX channel: 4/15 channels
12 Color wheel: 7 colors+white, rainbow
13 Gobo wheel: 5 gobos+open, shaking
14 Control mode: DMX512 /Sound/Auto/Master/Slave
15 Prisim: 3-facet prism
16 Focus: Motorized
17 X: 540 degrees
18 Y: 210 degree
19 Beam angle: 13
3 Voltage: 90-240V
7 Power: 90W
16 Focus: Motorized
17 X: 540 degrees
18 Y: 210 degree
19 Beam angle: 13
- djSupport
Re: NEED HELP
Freestyler is free, why did you buy it?
guan2015_2015
guan2015_2015
Re: NEED HELP
i try created the fixture for this moving head,,,,,
so i am newbie and i am blind,,, and i got 12 moving head,,,
i got fixture creator,,, the moving head got 005-015 channel
guan2015_2015
guan2015_2015
guan2015_2015
guan2015_2015
Re: NEED HELP
OK jai trouve rle probleme, et ses regler merci encore,,,
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: NEED HELP
fixture creation can be a lot of work, there is a link on the forum to purchase someones time to produce a new fixture for you.
To do this your self use the fixture in 15 channel mode
PAN 8 bit = 1
tilt 8 bit = 2
intensity = 6
shutter = 7 closed 0, open 255
strobe = 7, off 0 slow 50 med 128 fast 250
1st colour = 8 no colours = 8
gobo = 8 no gobos = 6
you will need to play with the strobe values, and gobo and colour values and channel descriptions.
there is a good tutorial in the wiki how to use the fixture creator.
PAN 8 bit = 1
tilt 8 bit = 2
intensity = 6
guan2015_2015
Re: NEED HELP
thanks you Mattotone
i have finish this creator fixture,,, now all working,,,
next problem ,,, i am pro from use Lightjokey 2
so now i see freestyler is more complication,,,
my problem, is creation scene,, and now i search use key for move my scene show,, so nothing
style kayboard pc,, use 1-9....
i not need use Cue push play all time,, i need fast push button on my show night,,,
i am dj and lightman,,, style i use music,, i push button 1,, i need strobe white moving head i push buton 2,, after i come back button 1,,,,
so nothing,,,
thanks again
so nothing,,,
thanks again
guan2015_2015
Re: NEED HELP
guan2015_2015 wrote: 07 Sep 2020, 20:24 thanks you Mattotone
so nothing,,,
thanks again
i can give you my facebook, or my email if you want
