Problem with Cue Topic is solved
- Just started using FS
- FreeStyler Version: 3.6.51
Problem with Cue
Hi everyone. I need your help. I Have 4 moving heads. Creating a sequence of 2 steps. The first step is the Shine 1 and 2, a device 3 and 4 do not Shine. Step 2 - not shines 1 and 2 the device, shines 3 and 4. Reproduce the sequence fully. Everything works as it should - the devices are switched on in pairs. Save. I put this sequence in the cue list. I save the cue list and place it on the cue button . When you click this button, the sequence starts playing, but the devices do not change their dimmer settings. Why?
- FreeStyler Version: 4.01
Re: Problem with Cue
sounds like you did not save the dimmer settings in the cue. Remember that you must make the dimmer "on" in every step for every fixture that is included in your cue even if the value is zero. if you want to post your setup file here we can take a look
Here some screenshots(setup of sequence) and video(play the cue) with my problem: https://dropmefiles.com/8wGXu
You mean setup of sequence or program?
Do all fixtures have the their own address?
I think this is a bug in the newest version, i have exact same problem when i attempt to program that.
Please fill out the bug report and submit.
Done. This problem in version 4.0.0 and 3.6.51
