Bezier Shapes sequence lights on and off Topic is solved
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.1.7
Hello, I offten make a one step sequence with the Bezier shapes window with my moving heads. When I start the sequence it all works well, when I stop it the moving heads stop but just in there last position and still stay on, is there a way to do it, when I run the sequence they are all moving and the lamp is on, and when I stop the sequence they stop and they turn off (Lamp) thanks so much for any insight.
perrip
Re: Bezier Shapes on and off
I'm not sure I worded that correctly, so I do a one step sequence in this mode (see image) and it works perfectly running in a cue. when I stop running the sequence the lights stop moving but the lamp stays on. How do I get the lamp to turn of as well? Thanks so much!
- FreeStyler Version: Beta
Re: Bezier Shapes sequence lights on and off
I am not sure how you operate the sequences.
But in general when you stop a sequence then it stops at the step it is on when the stop is given.
If the light is on then the light stays on. (There are so exceptions where it restores previous values)
The way I would do it is creating a sequence with the light shut off.
Then instead of stop then shift to the light off sequence.
I have a lot of color sequences on one cue and control it in the sub master.
One of them is "black_out" so when I shift colors and want to shut off the light then I shift to sequence "black_out".
Hope this helps.
Hope this helps.
perrip
Hello Jan, Thanks so much for the tip, I will do that. I have never had the best luck with sub masters, so I use mostly a lot of cues set up with different color schemes. If you ever have a moment, I would be really interested to hear how integrate your cues and sub masters
perrip
Great, Thanks so much!
