looking for a profile for tomtop/lixada 60w mini led spot.
when i purchased these lights they were advertised as lixada....
when i recieved them, the lixada name was nowhere to be found.
on the box it says manufacturer is Shenzhen/TOMTOP.
the only manual that came with them was a piece of paper with some dmx info.
any help would be appreciated.
tomtop/lixada 60w mini LED spot Topic is solved
djgarbo1
- FreeStyler Version: 3.5.1
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.1.7
Re: tomtop/lixada 60w mini LED spot
That is a pretty common one, here is a profile that should work for 11 channel mode, you may have to adjust the color wheel in fixture creator, they are often all a little different.
LED Moving Head 11 ch.pff- (54.22 KiB) Downloaded 110 times
djgarbo1
perrip
Downloaded file..
Can't be the right one...
mine has 14 colors, 8 mono 6 split not 11
Mine also only has 8 gobos not 11
Downloaded file..
djgarbo1
I got it all figured out EXCEPT the macros.....everything else is working.
perrip
sorry everyone is different, but not hard to adjust
