Saving/Restoring Submaster Sets Topic is solved
Vard
- FreeStyler Version: 3.6.3
- I Use FreeStyler for: Band
Most of my shows are done live from submasters. At the moment I am limited to 20 live submasters. Is there a way to save the submaster sets and restore them (ie all 20 of them in one go)? Cheers
- djSupport
Re: Saving/Restoring Submaster Sets
You can save them as a 'cue' and load them back by opening the cue using the folder icon and save icon on the submasters window, I've never used submasters but just checked this, please confirm if it is correct.
xever
- Twitter: www.120db.uk
There is no current way of saving sub-master layouts whilst Freestyler is Live, you can either use Backup / restore or edit the config file whilst Freestyler is closed.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
"Quick Submaster sets" are added in the next release (v4.1)
Vard wrote: 01 May 2020, 03:13 Most of my shows are done live from submasters. At the moment I am limited to 20 live submasters. Is there a way to save the submaster sets and restore them (ie all 20 of them in one go)? Cheers
Raphaël
