Chauvet 4 play CL Topic is solved
Djprimetime87
- FreeStyler Version: 3.4.6
Chauvet 4 play CL
I am new to freestyler and have been working with some of my fixtures. I was wondering, I have a Chauvet 4PLAY CL Bar. Would that be the same thing as the Chauvet 4bar listed. Mine is only a 6 channel fixture but freestyler has it as 15. Can someone help. I do have the manual
- FreeStyler Version: 4.1.7
Re: Chauvet 4 play CL
Based on what I see from the Chauvet web site they are different devices.
You will need a new fixture definition for your 4PLAY CL Bar
Djprimetime87
Can you create a profile for me for the 4PLAY CL Bar? 6 channel
This is an interesting instrument.
Attached is an attempt at a Freestyler fixture definition.
If I counted correctly each individual light has 37 different color settings. I think the Freestyler workspace would be very cluttered if a window or windows displayed all 148 settings as graphics - I choose not to do this.
If you open the Macro window you will see a few settings. These simply set all 4 lights to the same value - the values are the more simple color settings. Not being able to actually see the output of the lights I do not know if the graphics I chose are good representations of the colors or not.
Be sure you understand the DIP switch setting on each light.
I've also attached the User Manual.
4PLAY_UM_Rev4_WO-1.pdf- (1.1 MiB) Downloaded 33 times
Chauvet_4PLAY_CL.pff- (85.83 KiB) Downloaded 48 times
Djprimetime87
K, thanks, ill try it out
Djprimetime87
So far everything looks good working fine
