Cue Problems
- FreeStyler Version: 3.6.50
- Twitter: qi_loneranger
- Instagram: Qi_loneranger
Cue Problems
Hey there. I just download the freestyler software. Can i know why my moving head when i play the cue,it start moving but in 4 second, it stop moving and then it continue moving even the cue just keep playing.
- FreeStyler Version: 4.1.6
Re: Cue Problems
I apologize if I do not understand the problem you are having.
My understanding is that you have a sequence running in a cue. Do you have Loop ON / Loop OFF set to Loop On (2 green curved lines with arrow heads?) of Loop Off (straight red line with arrow head). If Loop On is set the sequence will continuously repeat until you stop it.
