device enttec open usb
puts out random values after 130, anyone had this problem ?
art-net to DMX wrong values Topic is solved
skineris
Nathanrs93
- FreeStyler Version: None
Re: art-net to DMX wrong values
Have you got everything set up correctly? Drivers in the correct folders?
kwstassarl
- FreeStyler Version: 3.6.51
hey i have the same problem..i tried vibrio(ios) magicq and dot2 all values go crazy above 136 for me since i upgrade to the latest windows update..please anyone has an answer? ive been using it for a year so im pretty sure i set up eveything corectly
- djSupport
Try to update the latest drivers to https://www.ftdichip.com/Drivers/CDM/CD ... tified.zip
Details on that and how can be found in this document that it advises you to read before updating https://www.ftdichip.com/Support/Docume ... 000073.pdf
