Hope you find this interesting guys, they chose a montage of 3 songs for their first dance, I then created a 6 step cue sequence to match
www.pwes.co.uk/howto.html You will probably want to stop the first video, the second one is what I'm talking about here, and this will autoplay
This was completed using 2.95H
All comments are welcome !
Bride & Groom first dance, 3d + live video Topic is solved
- djSupport
Re: Bride & Groom first dance, 3d + live video
adobe -premier? what is your main use for that? I had a look and it conmfuses me cause i dont understand what its for I have adobe after effects which I'm morwe fluent in...
PWES
Sorry mate, only just saw your reply !DJ Support wrote:adobe -premier? what is your main use for that? I had a look and it conmfuses me cause i dont understand what its for I have adobe after effects which I'm morwe fluent in...
I do lots of video, B&G first dance etc. Always used to use Premier, then got after effects, then moved to Mac and am now using Final Cut Pro which really is the business for editing !!
