Icon Symbol Topic is solved
tbully
FreeStyler Version: 3.6.51
Icon Symbol
Post by tbully »
Hello All -
Casual user here... I just fired up Freestyler after being away from it for several months. I thumbed through the wiki and couldn't figure this one out....
What's the blue arrow on the fixture icon mean? (attached) The fixture works fine - just curious.
Thanks!
FreeStyler Version: 4.1.7
Re: Icon Symbol
Post by Rod_Horning »
I have never seen this. Please open the picture that is attached to the fixture in Paint or some other photo app. If the arrow is there then it is simply a part of the photo and not related to any Freestyler function.
tbully
Re: Icon Symbol
Post by tbully »
It's good to hear that you've never seen this. I read through pages and pages of documentation trying to find it the other day.
The arrow is absolutely coming from the application. Other fixtures of the same type do not have this arrow. Just this one.
It goes away when in sequence-edit mode and if I to reset all fixtures (which I don't want to do, of course).
Re: Icon Symbol
Would you mind creating a backup using the backup/restore feature of Freestyler and posting it? That might assist in determining what the symbol means unless Jan or someone knows.
Or use the fixture creator to export the fixture definition and post it here.
Re: Icon Symbol
The clone feature, Right click 'Clone'
Re: Icon Symbol
tbully
Re: Icon Symbol
Post by tbully »
That's it! Thanks. I must have cloned another fixture to create this one. I'll have to retrace my steps to see if I can identify its partner.
Thanks again.
Re: Icon Symbol
If you click the clone again it should show you what it's cloned as...
Re: Icon Symbol
Post by Jan_K »
That one was also new to me. :)
Re: Icon Symbol
One for the wiki!
Re: Icon Symbol
Post by Jan_K »
It is added. :)
Re: Icon Symbol
Good man!
