LED Disco Ball LED RGB Digital Crystal Magic Ball Light Effect DMX 512 Disco DJ Stage Lighting
pd2
FreeStyler Version: 3.4.6
Post by pd2 »
I bought this for a party and it works in automatic mode! But I am not sure what it is. Is it in the list of supported devices?
I couldn't find the same description in the list of supported devices.
I am happy to have a crack at writing a setup file but not sure where to start. So any tips welcome.
dmx light.pdf
(110.8 KiB) Downloaded 34 times
There is no manual for this, only a small sheet.
I got it from this Amazon link if it is any help. https://www.amazon.de/gp/product/B07SJK ... _qh_dp_hza
Thanks to anyone who can start me off in the right direction.
FreeStyler Version: 4.1.7
Re: LED Disco Ball LED RGB Digital Crystal Magic Ball Light Effect DMX 512 Disco DJ Stage Lighting
Post by Rod_Horning »
According to the information on amazon your instrument can be controlled via DMX. If DMX control is in effect then the instrument uses 6 DMX addresses. Rotation, color and strobe can be controlled with DMX.
Set up a 6 channel generic fixture. Play with the various channels to see what they do then the fixture definition can be updated.
pd2
Post by pd2 »
Thanks for starting me off. I used the Generic Chinese Ball file.
And I got the following results which are different to the generic.
Channel 1 LED group selection and intensity
Channel 2 Yellow/Red intensity
Channel 3 Green/Purple intensity
Channel 4 White/Blue Intensity
Channel 5 Strobe
Channel 6 Absolute position/speed of rotation
Hope that this helps someone else.
Thanks again.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
pd2 wrote: 21 Feb 2020, 08:56 Thanks for starting me off. I used the Generic Chinese Ball file.
Channel 5 Strobe
Thanks again.
It does and doesn't help as we need DMX values, so we can correctly configue a fixture file.
