Can someone please create a fixture profile for this fixture? (9 channel mode)
Manual: https://downloads.monoprice.com/files/m ... 170822.pdf
Monoprice Moving Head Stage Wash RGBW - Request Topic is solved
jacobpassam
- FreeStyler Version: 3.6.51
- I Use FreeStyler for: None of your damn business!
- FreeStyler Version: 4.1.7
Re: Monoprice Moving Head Stage Wash RGBW - Request
Attached is my attempt at 9 channel fixture for your instrument.
You can open the Freestyler programming windows by clicking on Window->All after you select the instrument.
Your feedback is welcome.
You may find that the pan/tilt movements are not fine enough for your needs. If so then the 14 channel version may solve the issue.
Stage_Right_Wash_7x10W_LED_mh_9ch.pff- (20.26 KiB) Downloaded 178 times
