i'm new with this program.
I have a Pixelbar 18Q4 but can"t find any fixture for this model
try to make it myself without success.
it have 3 - 6 - 72 channel option.
anyone that have the files for this light?
kind regards
Showtec pixelbar 18 Q4 Topic is solved
Didden
- FreeStyler Version: 3.4.6
- FreeStyler Version: 4.1.7
Re: Showtec pixelbar 18 Q4
Attached are 2 fixture definitions for your instrument. One is the 6 channel version and one is the 72 channel version. The Freestyler programming windows will open if you click Window-->All after you select the fixture.
The 72 channel version used Freestyler's RGB segments feature. Select the fixture and open the Colors window (it will open if you clikc Window-->All). At the bottom of the Colors window are several check boxes. The 18 larger boxes represent the 18 RGBW segments of your instrument. Freestyler will send DMX values to the corresponding RGBW segment of each checked box. The segments which are not checked will not be sent new DMX values.
The smaller (probably colored green) box with a check mark provides shortcuts for placing check-marks in the segment boxes.
Note the top and bottom of the segment check boxes reflect the color of the segment.
IMPORTANT. Make sure the fixture definition you add to freestyler matches the physical configuration of your instrument and that the starting DMX address of your instrument and the starting DMX address of the fixture match!
Your feedback is welcome.
Showtec_Pixel_Bar_18Q4_72ch.pff- The 72 channel definition
- (20.71 KiB) Downloaded 55 times
Showtec_Pixel_Bar_18Q4_6ch.pff- The 6 channel definition
- (19.71 KiB) Downloaded 52 times
