to learn freestyler i install 4 second hand par56 led "no name".
is there a standard fixture for this low cost matériel.
thanks.
Best regards.
aliexpress and other china export
admix
- FreeStyler Version: 4.1.7
Re: aliexpress and other china export
The fixture library contains several fixture definitions with "par 56" in their name. You can try these to see if they match your instrument.
There are many variations of channel configurations of LEDs. The only "standard" would be a generic fixture with the number of channels used by your instrument. - usable but not very easy to program.
If you can determine the function of each channel of your instrument a fixture definition can be created.
mpetersen
- FreeStyler Version: 2
Hi Admix,
Do you know what the DMX channel count is for them?
- djSupport
The easiest way to check this mpeterson is to use a blank fixture file from the forum for let's say ten channels,
Then use the slider window on the right open it up and adjust the values from top to bottom, when the next slider no longer does anything then count the sliders before and that'll give you how many channels it is, you can also use this for determining values for fixture creator if you don't have a manual
