I need fixture for this laser. I have tried some fixtures but it didnt work well.
CR Tec power 7
niitro
- FreeStyler Version: 3.4.6
CR Tec power 7
Hi!
- FreeStyler Version: 4.1.7
Re: CR Tec power 7
Please review the attached PDF. Is it the correct manual for your instrument?
CR_TEC_Power_7_manual.pdf- (576.55 KiB) Downloaded 4 times
niitro
Re: CR Tec power 7
Hi! Thanks for reply. That's not manual for my laser. This is the right one
Re: CR Tec power 7
Thank you for uploading the manual. It will take some time to create the 30x30 clips of the patterns for inclusion into the fixture definition. Check back in a couple of days and hopefully I will have completed and upload the fixture definition.
niitro
Re: CR Tec power 7
Many thanks!
Just keep in mind, in pdf manual several laser is include, power 1/3/7 and N. My laser is power 7 and DMX channels for my laser is on the bottom of the 11 page and patterns are on the last 12 page ...
Re: CR Tec power 7
Hopefully I have used the correct parts of the manual.
The attached fixture definition should work. I am posting it for you to test and provide feedback. Additional helpful programming windows will be added, such as custom sliders where appropriate.
Remember to open the programming windows. Click on Window->All
Only the group 1 patterns have been added (see the Macro window). I will be adding the others.
The Color wheel shows a rainbow for the Move, Jump, Roll functions. If the rainbow is not a good representation of the effect please describe the functions and I'll see if I can provide a better picture.
CR_Tec_Power_7.pff- (84.96 KiB) Downloaded 4 times
niitro
Re: CR Tec power 7
Partial macro is right and another is wrong. Maybe this manual is not full for this laser either, i have seen some macros on my laser today that is not on this manual at all, and then, I have found on forum where someone take picture of user manual that is definetly for my laser, if that is ok?
And thanks again for this! Many thanks!
niitro
niitro
Re: CR Tec power 7
Some patterns are the same, some different which explains why the macro is not correct.
If you can find a PDF of the correct manual the pattern pictures will be much better than what will SNIP from the pictures.
I will work on updating the macro over the next few days. If you have any other feedback please post it.
niitro
Re: CR Tec power 7
I cant find pdf manual, i have searched anywhere, all day long i have searched on forums and anywhere...
simple, there is no pdf manual for this laser. I have send email to Cr Tec to send me pdf manual, but they dont answer me yet.
Re: CR Tec power 7
OK. Thank you for trying. I will work with what we have. It will take me a few days
If you can take a photograph with the pattern page very flat that will be good enough.
niitro
Re: CR Tec power 7
I cant, its not my user manual, its from pioneer forum user. But i will try to draw patterns in corel, at least some of them. And thank you again.
- FreeStyler Version: Beta
Re: CR Tec power 7
An other way to do it is to setup the laser manually to each pattern and take a photo.
Then cut and resize it to it fits the 30x30 size
niitro
Re: CR Tec power 7
That's interesting also. I will try that.
Re: CR Tec power 7
I reviewed all of the PDFs on the CR web site. Apparently the web site has an incorrect link or links as none of the PDFs contain the picture you shared from the Pioneer forum.
I sent an email to the company requesting them to update the link to the correct PDF and to send me an email with the correct PDF. Hopefully they will honor my request.
