Chauvet Colorband Pix-M
oz_music
- FreeStyler Version: 3.6.50
Hi Users, I am looking for a profile for a Chauvet Colorband Pix-M 42 Channel
- FreeStyler Version: 4.1.7
Re: Chauvet Colorband Pix-M
Attached is my attempt.
The built in chases are defined as Gobos, thus they can be accessed via the GOBO programming window
The dimmer modes can be set via the Macros window
Freestyler's RGB segments feature is used to define the 12 RGB LEDs and can be accessed via the COLORs window.
Your feedback is welcome
Chauvet_COLORband_Pix_M_42ch.pff- (50.73 KiB) Downloaded 106 times
milan41
- FreeStyler Version: 4.0.1
Hello, I would like to ask you for help with setting up the Freestyler program to which I have an Enttec DMX Pro converter, 4x wash heads, 3 lights and 3 colorbands, all from Chauvet. We managed to control the lights via Freestyler, but we don't know how to set the program so that the lights respond to music, this is the Sound2light function. If you knew what to do with it, I would be grateful. It is possible to log in to the PC via TeamViewer. Thank you M.Marek
