IM-MH90S 90W LED Spot MH Light Rotating GOBO 3 Topic is solved
andrei.iacobescu
FreeStyler Version: 3.6.4
Post by andrei.iacobescu »
Hi guys,
For over a week I am struggling to find or to create a fixture for the MH you can see in the subject field (a chines moving head from IMRELAX)
It is impossible to find a clue anywhere, so if someone will be able to provide a fixture for this model, will be deeply appreciated.
Here is the link to the manual of the product:
http://www.imrelax.com/im-mh90s-new-90w ... ual-video/
Link to product description:
http://www.imrelax.com/albums/im-mh90s- ... ead-light/
Thank you,
Have a great day.
FreeStyler Version: 4.1.7
Re: IM-MH90S 90W LED Spot MH Light Rotating GOBO 3
Post by Rod_Horning »
Attached is my attempt at a fixture for your instrument.
Help programming windows available:
Beam
Gobos
Lamp
Macros
Custom Sliders
Pan/Tilt
The manual did not show the gobos or the colors. If you can supply the colors and gobo images along with their DMX values I can update the fixture so that it is more useful. There is no helpful programming window for the Channel 8 color control because of this lack of information.
IMRELAX_IM-MH90S.pff
(107.9 KiB) Downloaded 41 times
