Having pan and tilt not change
mattspunkm
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Twitter: twitter.com/mattspunkm
Post by mattspunkm »
I have multiple color sequences that each have the same movement pattern. I want the movement to stay continuous as I select each sequence. It resets each time I choose a different sequence. Is there a way to do this? Thank you.
FreeStyler Version: 4.1.7
Re: Having pan and tilt not change
Post by Rod_Horning »
Check the channel settings in your sequence(s). There are 3 settings, fade, snap, ignore. If the pan/tilt channels are not set to ignore this will cause your problem. Otherwise the problem could be inherent in the operation of the instrument.
Upon rereading your question I do not think my previous answer is correct.
You need 2 sequences to run simultaneously.
One sequence to control the pattern movement
The other sequence to control the color.
Place each of your sequences in the Cue List
Click on the left most gear icon
Click on Cue Multiselect always enabled
Make sure the movement pattern sequence is set to loop
Start the movement sequence
Start the color sequence
When ready start the next color sequence (if the 1st color sequence is looping you will need to click on it to stop it)
Hope this is the correct answer
