Ibiza LMH MiniWash
blackshadow
FreeStyler Version: 3.4.6
Ibiza LMH MiniWash
Post by blackshadow »
Hi , I need fixture for Ibiza LMH MiniWash RGBWA+UV
Thanks alot
https://www.ibiza-light.com/media/catal ... SH_man.pdf
FreeStyler Version: 4.1.7
Re: Ibiza LMH MiniWash
Post by Rod_Horning »
Please test and provide feedback.
Helpful programming windows may be displayed by clicking on Windows All
ibiza_6in1_18ch.pff
(93.14 KiB) Downloaded 63 times
blackshadow
thank you, I just added the Shutter channel , otherwise the LEDs will not light up
Would you please EXPORT and upload your updated fixture?
Thank you
The way I understood the user manual is that each of the color LEDs were controlled by their own channel. At least one of these would need a non 0 value.
PLUS
The master dimmer channel would need a non zero value.
blackshadow
ibiza_6in1_18ch.pff
(93.15 KiB) Downloaded 72 times
Thank you.
jerome C
Post by jerome C »
Bonjour à tous
je n'arrive pas à mettre la lampe en open
est ce qu'il y a une manip particulière a faire svp ?
merci a vous
