showtec shark spot one and adj pinspot led quad dmx Topic is solved
dennisgamalej
- FreeStyler Version: 2
Guys can someone pls make fixture for showtec shark spot one and adj pinspot led quad dmx?
Thank you so much guys:)
pinspot_led_quad_dmx.pdf- adj pinspot led quad dmx
- (690.46 KiB) Downloaded 27 times
45023_MANUAL_GB_V1.pdf- showtec shark spot one
- (2.31 MiB) Downloaded 23 times
- FreeStyler Version: 4.1.7
Re: showtec shark spot one and adj pinspot led quad dmx
Attached is my attempt at a fixture for the ADJ Pinspot
Please test and provide feedback
ADJ_Pinspot_LED_quad.pff- (28.31 KiB) Downloaded 24 times
Attached is my attempt at a fixture for the Showtec Shark Spot One - 14 channel mode
Programming windows available
Gobo
Color
Custom Sliders
Pan/Tilt
Channel 13 has a mixture of functions. I did not code macros or custom sliders for this channel so please refer to the User Guide
Your feedback will be appreciated
Gobo
Color
Custom Sliders
Pan/Tilt
Showtec_Shark_Spot_One_14ch.pff- (75.27 KiB) Downloaded 33 times
dennisgamalej
Thank you so much everything works amazing
That you for the feedback.
Enjoy!
Enjoy!
- FreeStyler Version: Beta
Hej
I get an "Invalid picture" error when I try to import the "Showtec_Shark_Spot_One_14ch.pff"
Anyone having the same issue.
I had the same issue.
Attached is a recreated fixture. It Imported OK.
My only guess is that the picture was to large. I reduced the picture size.
Hopefully I have the correct gobo and Color DMX values as I do not own this instrument.
Rod
Rod
Showtec_Shark_Spot_One_14ch.pff- (83.71 KiB) Downloaded 39 times
Hej Rod
Thanks!
I just needed to verify that it was not an issue on my PC.
Thanks!
You are more than welcome.
Sorry for the problem.
I just reported it so Raphael can have a look at the issue.
An import error is always critical.
