profile request for venue thintri 64 Topic is solved
imthemandigit
Post by imthemandigit »
I need the 8 channel version
I'm close but I cant seem to get the strobe working
http://venuelightingeffects.com/wp-cont ... Manual.pdf
FreeStyler Version: 4.1.7
Re: profile request for venue thintri 64
Post by Rod_Horning »
From the Fixture Creator please export your fixture definition and upload it to this thread.
Reading the manual you supplied (Thank you), channel 5 and 6 work together for the strobe effect (as well as the dimmer channel 7).
imthemandigit
thin tri 64.pff
(54.44 KiB) Downloaded 50 times
imthemandigit
I tried a few different ways but wasn't sure how to make those channels work together. thanks
imthemandigit
good news! I had the lights set to 3 channel. I'm a dope. switched them to 8 channel and they work great with that fixture. hope I didn't waste anyone's time. thanks
Glad you found the problem. Don't be hard on yourself, others have had the same issue!
