I bought these heads
https://www.aliexpress.com/item/3269007 ... 40b8j0p79W
I don't have a manual and I can't get them into freestyle. help you pls?
Thank you
GVT Light - Mini Spot 30W
MartinNess
- FreeStyler Version: 3.6.51
- FreeStyler Version: 4.1.7
Re: GVT Light - Mini Spot 30W
Contact the seller and see if you can get a copy (PDF preferred) of the user manual or a link to a list of the DMX channel functions. With that we can help you.
If that is not successful then you will need to experiment and find out the function of each of the 9 or 11 channels (depending on how you configure the instrument).
Find or create just a generic 11 or more channel fixture. Add it to Freestyler, making sure the fixture and your instrument are addressed correctly.
Using the standard Freestyler sliders, experiment with your instrument until you determine the function of each channel. Being a moving head with gobos and color LEDs I would expect to find Pan, Pan fine, Tilt, Tilt fine, Red, Green, Blue, perhaps White and/or UV, strobe, Master Dimmer, gobo selection and perhaps a channel to control built in chases.
If there is a master dimmer then at least 2 channels will need to be non 0 or the instrument will remain dimmed out.
Good luck.
Good luck.
MartinNess
I got this, but I don't know what to put in Fixture creator
the manufacturer has sent me a .r20 configuration file
It cannot be imported into freestyler
"LED moving head light instruction
-30W(spot light)"
Addr A001-A512 512 Address Setting
CHnd 11CH 11 Channels Setting
9CH 9 Channels Settting
SLnd MAST Host Mode
SL 1 Controller Mode
SL 2 Vice-machine Mode
SHnd SH 0 Effects 0(Recomment)
SH 1 Effects 1
SH 2 Effects 2
SH 3 Effects 3
Soud on Sound Control Open
oFF Sound Control Off
SEnS 0-99 Sound Sensitivity Regulatory
bLAnd bLAc No 512 Signal Zero
Auto No 512 Signal Auto
Soun No 512 Signal Sound Control
HoLd No512 Signal Remains Last console state
LEd OFF Off Screen After 5 Seconds
ON Screen Open All The Time
dISP no Show Reverse
YES Show Forward
rPAN no X Motor Forward
YES X Motor Reverse
rTiL no Y Motor Forward
YES Y Motor Reverse
REST YES System Reset
9CH Mode
Channels Function Explanation
1 Level operation 0-255
2 Vertical operation 0-255
3 Color
0-139 Color Choose
140-255 Automatic color change from slow to fast
4 Spot
0-63 Fix-Spot
64-127 Pattern Jitter
128-255 Wrap a pattern from slow to fast
5 Strobe 0-255
6 Dimming 0-255
7 Horizont alvertical operation Speed 0-255
8 Auto Mode 0-255 Upward adjust Forward, downward adjust reversal
9 Re-set 250-255(5s)
11CH Mode
2 Level Fine-Tuning 0-255
3 Vertical operation 0-255
4 Vertical trimming 0-255
5 Color
0-139 Color Choose
6 Spot
0-63 Fix-Spot
7 Strobe 0-255
8 Dimming 0-255
9 Horizontalvertical operating speed 0-255
10 Auto Mode
0-59 Other Channels Function
60-84 Auto Mode 3
85-109 Auto Mode 2
110-134 Auto Mode 1
135-159 Auto Mode 0
160-184 Sound Control Mode 3
185-209 Sound Control Mode 2
210-234 Sound Control Mode 1
235-255 Sound Control Mode 0
11 Re-set 250-255(5S)
Description: Sets the holding mode, first unplug the signal line 512, wait for 30 seconds,
Then turn off the power, the system automatically saves the last 512 signal
1.Key Show:
MENU:Function UP:ADD DOWN:subtract ENTER:Confirm
-30W(spot light)"
SLnd MAST Host Mode
SH 1 Effects 1
SH 2 Effects 2
SH 3 Effects 3
YES Show Forward
YES X Motor Reverse
YES Y Motor Reverse
9CH Mode
3 Color
0-139 Color Choose
4 Spot
0-63 Fix-Spot
5 Strobe 0-255
6 Dimming 0-255
11CH Mode
5 Color
0-139 Color Choose
6 Spot
0-63 Fix-Spot
7 Strobe 0-255
8 Dimming 0-255
10 Auto Mode
60-84 Auto Mode 3
85-109 Auto Mode 2
110-134 Auto Mode 1
135-159 Auto Mode 0
1.Key Show:
Attached is a fixture file for your instrument for the 11 channel mode (be sure to physically configure your instrument to DMX control with 11 channels)
If you can determine DMX values for the various colors I will update the fixture file with a color wheel.
If you can determine DMX values for the various GOBOs I will update the fixture file with a GOBO wheel.
The following helpful programming windows are available (click Window - ALL)
Custom Sliders
Lamp
Macros
Pan/Tilt
Please test and provide feedback
Custom Sliders
Lamp
Macros
Pan/Tilt
Cree_30w_LED_11ch.pff- (34.41 KiB) Downloaded 197 times
MartinNess
Thank you very much......its great !!!!!!
Thank you
Thank you
zeinerla
I have a bunch of 11 channel U King 30 Watt mini LED spot moving head lights. The file provided does not seem to cover all the dmx controls, also, im not sure how to load the file into freestyler as this the first time i ever used it. Any advice on how to import this file into system? Thanks! Here i have provided a link to the DMX addresses in case this helps. Thanks!
https://onyxfixturefinder.com/fixture/U ... i+LED+Spot
Rod_Horning wrote: 19 Dec 2019, 11:58 Attached is a fixture file for your instrument for the 11 channel mode (be sure to physically configure your instrument to DMX control with 11 channels)
Custom Sliders
Lamp
Macros
Pan/Tilt
In order to create a better Freestyler fixture I need the values for the color wheel, the gobos, shutter, chase and curve. While the Cree fixture I created should control your instrument using the standard Freestyler sliders it does not have, due to lack of information, all of the helpful windows and settings.
If you provide the DMX values I can create a more useful fixture for you.
Assuming you have Freestyler installed:
Download the fixture file
Double click on the file
This should run the Fixture Creator and install the fixture into the Freestyler libraries. From there, in Freestyler, you use Setup Add/Remove fixtures to add the fixture to the Freestyler work space. Make sure the address of the instrument and the starting address of the fixture match and that the instrument is configured for 11 channels if there are other options.
