Uking par 36
Arcticdream
Uking par 36
Hi can anybody help just new to dmx I bought a couple of cheap uking 32 par lights could anybody tell me are they similar to any others to get setup on freestyler as I cant find them on the list sorry if this has been asked before any help would be great thanks
- FreeStyler Version: 4.1.7
Re: Uking par 36
Can you post either a link to the user manual or upload a PDF of the user manual?
thefunkconductor
- FreeStyler Version: x2
Re: Uking par 36
I also have these lights (Uking 36 LED 72W PAR ZQ-B262-YK) and there isn't a fixture file for them to use in freestyler...
I have the guide that came with it and this is the only useful page in it:
https://ibb.co/vxS86z0
Can anyone help with creating a file?
Re: Uking par 36
Attached is my attempt at a fixture for your instrument.
Helpful programming windows available:
Colors
Lamp
Macros
Your feedback is welcome.
Colors
Lamp
Macros
Uking_36_LED_72W_PAR.pff- (6.6 KiB) Downloaded 276 times
thefunkconductor
Re: Uking par 36
That works perfectly! Thank you for your quick reply and taking time to make thisRod_Horning wrote: 11 May 2020, 14:20 Attached is my attempt at a fixture for your instrument.
Colors
Lamp
Macros
Re: Uking par 36
Glad it worked for you. Thanks for letting me know.
simmondp
Re: Uking par 36
Worked for me too, thanks!
gaffey1992
Re: Uking par 36
hi guys, im currently having issues with this, i have freestyler and downloaded the file but it still isnt working for me. any ideas?
- djSupport
Re: Uking par 36
it may be that you have it set to different channels, most units can be selected to operate on let's say 5 or 9 channels etc
TraceyT23
- FreeStyler Version: 4.1.0
Re: Uking par 36
This post is a bit older, but someone asked for a some help on this same fixture, so I'm going to add my fixture file here for him, and so others can use it if they like.
UKing_B262_RGB_Par_36.pff- (15.77 KiB) Downloaded 148 times
- djSupport
drbilly
- FreeStyler Version: 4.1.6
Re: Uking par 36
Thank you, this worked for me too
berto2002
Re: Uking par 36
Hmm, not working for me (neither of the above). Need to look into this more.
- djSupport
Re: Uking par 36
Uking seem to have a few lights that are similar but have different DMX values as well as SHEDS brand lights
66Kenny66
Re: Uking par 36
Hi, thank you very much, working (the both) for me
