Fun Generation Picowash 40 Z Topic is solved
dovjatinsh
Hello guys, because i'm dumb and i can't make fixure with creator, i hopefully want to request a fixture for this machine in 26 channel mode
c_412551_r2_en_online.pdf- manual
- (1.15 MiB) Downloaded 25 times
- FreeStyler Version: 4.1.7
Re: Fun Generation Picowash 40 Z
Hello
Attached is my attempt at a fixture file for your instrument.
Please test and provide feedback.
The following helpful programming windows can be accessed via Window->All:
Beam
Colors
Lamp
Macros
Pan/Tilt
Please note the 4 check boxes in the lower left hand cornor of the Colors window. These are the RGB segments. Each box controls the color for one of the LEDs. If a box is checked the corresponding LED will be controlled by the color pallet.
The Macros window controls the pre-programmed functions of channel 25. Clicking on the first box (the black one that says no macro) disables channel 25 and the instrument is then controlled via the other channels.
Beam
Colors
Lamp
Macros
Pan/Tilt
Fun_Generation_Picowash 40 Z.pff- (84.14 KiB) Downloaded 24 times
