created a new fixture but it's not listed in Freestyler Topic is solved
magicman
Post by magicman »
I created a new fixture in fixture creature
saved it
exported to freestyler
the problem is not listed in freestyler
any ideas, thanks
Re: created a new fixture but it's not listed in Freestyler
Post by Jan_K »
Hej magicman.
Please upload the file here so we can have a look.
FreeStyler Version: 4.1.7
Post by Rod_Horning »
I am a bit confused.
Normally when you save a fixture from the fixture creator it is saved in the Freestyler fixture folder. Where did you have the fixture creator place the fixture file?
EXPORT creates a .pff file. This file can then be uploaded to this forum or emailed. It is NOT used by Freestyler. IMPORT will extract the fixture from the .pff file and should place it in the Freestyler fixture folder.
