Run sequence for a minute, then next sequence
rudolfski
I have a couple of simple 4 step sequences that I like to run for a minute or so before changing to the next sequence in the cue list. How can I do this without making more, or longer steps?
- FreeStyler Version: 4.01
Re: Run sequence for a minute, then next sequence
Best way to me would be to loop the sequence and then create a trigger key that goes to next sequence that you can press when ready. Anything time specific would need to be programmed to exact length or use with timecode
