Hi everyone,
I'm fairly new to Freestyler and I read 90% of the freestylersupport sections so I think the answer to my question is no but I wanted to make sure with pros!
I have a cue list that controls color channels and tilt values (they are laser heads and I want to make sure they are always at a height above ppl's eyes). They are Chinese fixture from ali-express. Each color channel is slightly offset from a tilt perspective to so my sequences already account for that.
Now i was trying to put that cuelist in submaster slot 1, and the other cuelist with my pan FX sequences in sub 2. Now each have multiple sequences and unfortunately submasters only have one sequence active per cuelist loaded... Other than me manually triggering them via the "go" button or a manual click...how can i have it cycle through all sequences?
A single cuelist will cycle through all items just fine, but not if my pan and tilt sequences are separated.
My only solution so far is to "merge" all my pan sequences into a SINGLE sequence with many more steps and have it run on random.
Am i missing something ? Thanks everyone for the help and this software is the bomb.
Magika
Submaster question: Is there a way to have it cycle through all cue sequences?
- FreeStyler Version: 3.6.50
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Submaster question: Is there a way to have it cycle through all cue sequences?
I have quickly knocked together this addon for sequencing through cues within a submaster.
viewtopic.php?f=38&t=8611&p=33531#p33531
Thanks ill check it out!
