Contrôleurs MIDI
Jaykie
Contrôleurs MIDI
Post by Jaykie »
This is from the old forum
LaurentP
Bonjour, peut on utiliser ce genre de contrôleur MIDI: http://www.behringer.com/BCF2000/index.cfm?lang=FRE avec Freestyler ?
Merci
LJ Exodus
Oui, on peut employer ce contrôleur du MIDI (BCF2000) avec Freestyler.
J'emploie personnellement une BCF2000, et cela fonctionne grand. Il rend en utilisant Freestyler extrêmement facile.
laurentP
Thank you for your answers, i'll try a bcf2000 and i'll give you my report about this test.
Regards
DJ Support
god you even speak english! better luck in english or better in both if you have a problem
LaurentP
Hi, i don't understand what do you mean ? It's a joke
DLO_OL
e messieur te dit que t'auras plus de chance d'avoir une reponse en speakant anglais.. mais il est vrai, sur un ton famillier. pffff, un ingenieur qui se fait expliqué l'english par un techos ....
DJ Support
i think he said what i mean, if you post in both english and your native language you will get twice the chance of getting your answer
JuKom
Freestyler is a very nice programm, i had my first event with 2 MHs and 2 SC, I controll it with a keyboard, everything works nice
but next time I need to controll some dimmer for theatre, so i need some faders, and the question is, can I use the BCF2000 and could I do it like fader-1 = channel-1, fader-2 = chnannel-2 ....
and fader-8 is master for the rest ? is this possible ?
thx for an answer
Julius
Return to “BCF2000”
