Hello, how can i disable color fade from led pars in submasters?
Thanks!
Submaster Fade Colors
Motsik
- Twitter: http://twitter.com/#!/motsik
- FreeStyler Version: 4.01
Re: Submaster Fade Colors
you can either build sequence using snap or fade OR you can select to disable fade in the cue window right click menu.
